looks good!! was there a thread on your build? id like to know more about your procharger set up.
Its a 500 inch 8.5 compression Indy Ez heads with a little clean up and a F1X procharger small crack pulley tooth (7 inch) and 44 tooth on the head So it reva at around 56000 rpm The max for this supercharger is 72000 rpm It can certainly be bumped up a lot!
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
