Originally Posted By floridian
Assuming the car will not be moved?
Blocks of wood
Jack
car stands
My solution also... with non-hydraulic jack so it does not creep down. It is possible to rig supports between the T bars also... always with a block of wood between the back of the oil pan any any steel supporting it.
