I pulled the driver side valve cover off and found that I'm missing the #5 intake pushrod. Haven't taken the intake off to see where it went. I guess the lifter popped out and the pushrod went into the pan. I hope to get a better look this weekend. It has a wet sump stock oil system!
Thanks for the update and glad you tried the priming suggestion before starting the motor. So much for
