Bill, I've used Accurate's stuff. VERY nice, perfect fitment, etc and Tom is always available if you have questions. He uses the actuall cars to fit all the pipes. I have a set of his factory Mufflers and Tail pipes on my 66 Satellite right now, including hangers/clamps. I had the head pipes bent locally (BIG mistake !!!) and spent 2 days cutting/re-welding their scrap. this after the guy said "you know, I've done one or two of these before" then used a prybar on the floorpan to clear his misbent pipes
the only consolation is the local shop used heavy guage pipe. I also found that the repop (Y.O.) front hangers are 1" too short (66-7 B-body application) and caused the mufflers to hit the floorpan. I wound up using cheapo stuff, set at the correct height until the Accurate ones showed up. I will be using Accurate brand stuff on the Belv II and probably the 'Cuda when it's ready.
Todd
