what are some tips and tricks to keep the advance plate more steady in the distributor?
I had to change the pick up coil in the distributor the other day.
I set the reluctor air gap to .008 like specified by Mopar.
But the problem is once the vaccum advance is applied the reluctor teeth start smacking into the pick up coil post because of how bad the advance plate wobbles around.
Is there anything else I can use to hold the pick up coil unit to the advance plate other then that strange little triangle shaped clip that comes in these distributors?
I feel like thats the problem area right there.
If there is anything I can do, like maybe a snap ring that fits tighter or maybe wrapping the little post that is on the pick up coil plate that goes through the advance plate with some tape or something to make the fit a little more snug?
