you'll need two things a 3 speed switch and the correct arm. The 2 speed arm WILL NOT work with the 3 speed. Do NOT use it or you will burn up the 3 speed motor quick.
[IMG]http://i66.tinypic.com/pui5j.jpg[/IMG]
Coming soon!!!!
