I don't know how relative it is, but I have seen pcv valves get stuck open, and when the vacuum gets too high, it would cause the crank seals to suck air and howl like a reed valve. Since your noise isn't following rpm, I'm thinking some sort of gasket or seal might have a similar condition. Open your oil fill to relieve vacuum and see if the noise goes away.
[image][/image]
