If you find out what the specs are on the cam for your 74 RoadRunner with 400 motor, most major cam companies will grind you one to those specs for just a few dollars extra. They may even have the stock specs for that cam on record. Just give one of them a call. Crane, Comp Cams, Lunati, etc, etc.
