It's a long post... is there anyone that mentionned a problem with the engine generating too much heat? Seems like your trying to fix the symptom, not the cause. What is the cranking compression in each cylinder? To do this test, pull all eight plugs with the engine warmed up, and see what the gage tells you. Sounds like the thing has running issues.
Well, art is art, isn't it? Still, on the other hand, water is water! And east is east and west is west and if you take cranberries and stew them like applesauce they taste much more like prunes than rhubarb does. Now, uh... Now you tell me what you know.
