I'm pretty confident my suggestion will fall upon deaf ears........ But............ I'd just put back on the stuff that was working before and not worry about the 5-10hp you might be losing.
68 Satellite, 383 with stock 906’s, 3550lbs, 11.18@123 Dealer for Comp Cams/Indy Heads
