How much can a good std journal 273 crank be offset ground? Can it be ground down engough to use the honda rods? There are no holes in the throw so it should be OK right?
Yes. If ground to HRJ with max offset the rod oil holes will be in the same place as if you ground the rod journals to a normal undersize. I'll have to check what the stroke increase is.
