you'll effectively destroy an otherwise good crankshaft if you take it to 1.88 journal size on an offset grind for the aforementioned reasons. the oiling holes will be right at the cheek of the fillet.
So an offset grind with honda journals is a no-go. But just grinding down to a honda journal is ok on the oiling hole placement??
Thanks.
Now the stock big block cranks don't have a problem going to honda journals? Is that correct?
