Originally Posted By autoxcuda
Originally Posted By rustbuckett68
You could clearance the fronts (or rears) the old way. Put a wood baseball bat between tire and fender, and roll car back and forth, by hand. If more space is needed, put some hefty buddies on the hood and repeat
If you do that, roll the bat and hit the outside with a rubber mallet. Or some sort of soft headed mallet. I used a leather mallet shown in the pic.
That supports the hit. Same idea I stressed before, small hits. Slowly work the metal.
Steve, are you the one with the hammer? eek
“So if it’s on the internet it must be true”
Abe Lincoln
