Originally Posted By Morty426
Does it use the under dash type?
IIRC it does, mounted to the left of the ash tray, generally where you find the reverse light indicator on a 4spd equipped A body, IIRC the 71 A body rear speaker/fader switch when ordered was a dealer only install
