Also keep in mined that when the #1 cylinder is at top dead center the slot in the oil pump drive gear should be facing straight front to back of the engine. If not. you'll have to re do the plug wires to where the rotor is pointing. Do it right , less confusing later.
it's ok to butt heads, just don't do it with a butthead
