Originally Posted By PurpleBeeper
Originally Posted By John_Kunkel
Use your priming rod to turn the pump a little and then try installing the intermediate shaft again. If no go, repeat.
I agree. You're trying to line up BOTH the hex end of the drive shaft & the gears on the cam. It sounds like one of those two is off slightly and John's idea would work just fine.
Yep. Or you can rotate the engine with a breaker bar slowly. This will rotate the cam gear and intermediate shaft until the hex lines up with the oil pump.
Two ways to do the same thing. Good luck.
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
