The 727 won't drop from 3-2 on deceleration, it drops from 3-1 when the speed is low enough. The reason for this is to prevent the lurch that would accompany the 3-2 downshift...since there is no coast braking in 1st gear in Drive, there is no lurch as it shifts down when rolling to a stop.
If it kicks down to 2nd with part throttle when rounding a corner, it has PTK.
