Originally Posted By GY3
Originally Posted By mopar dave
I remeasured with tires on and looks like 1/2" longer would be perfect. 21" would be back too far.
They are split mono's. Redrill and put the center pin where you need it. I had to on mine.
Did mine the same way.
1968 Charger COLD A/C Hilborn EFI
512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim
2020 T/A 392 Stock 11.79 @ 114.5
