Originally Posted By Chris Johnson
I have no experience with standalone EFI, but if you have the flexplate and MSD 6-Hemi (p/n 6013), the MSD harness that is applicable for your application (p/n 88863 for '05 running carb), + the fueling of your choice, you are good to go. The build above that I built the intake for, all I had was a complete engine with no harness's, and the only parts I bought were the MSD and the flexplate to make it run.
The harness you used is now obsolete and the replacement has different connectors that I think are for the 6.1 coil packs that were used in 2006. I have the flexplate, exhaust manifolds and pan already and now doing the research on low intakes for hood clearance. Do you know of anyone that has remote mount coils other than Indy?
