Another option would be to start with a 2009+ 5.7, keep the fuel injection, and add boost. At 3500 lbs, the stock 5.7 with boost should get you mid 10s and be a reliable pump gas daily driver if you choose. I made 535 at the tires with only 7 psi on a stock 5.7 with a super safe tune.
1975 Jeep Cherokee compound turbo 5.7 Hemi/6 speed AutoX/Drag/Street.
9.97 @ 140 slicks, 10.74 in autox trim
