CS130D is a Delco unit, it's pretty good. I think I read you have a Denso on yours now Mr. P? I would just up that one to your needs, less weight, less rotating mass, everything already lines up and you don't street drive it
I will be using this on my Rampage.. its street driven with injection... the part that Willie shows below is pretty much what I think I need but with a single pulley.. assuming this is the same size as the 70a thanks
