Did you guys really get 90 cc from original 906s back in the 1970s?
Back then, when I measured unmolested, uncut, no valve grind, and no sunk valves I got about 87 cc. I suspect that anything measured in the last 30 years would likely not meet this criteria. One valve grind is probably 2 cc.
