Originally Posted By jerseybud
Charging is controlled by the computer from 88-up 5.2 and 89-up 5.9 trucks. Usually throws a code 41. The external regulator is a common fix, but its supposed to be on the firewall and grounded case to the firewall, not just dangling on the valve cover.
What is code 41? What happened that made the previous owner splice in a voltage regulator?
