I used the large tube A body TTI in an F body. Why would that not work with a M body?
I made my own mounts, rather than buying. The passenger side header can almost fall out if you remove the bolts. Driver side requires the usual tricks to install and remove.
Too many cars, too many parts, too little coin, too little space to work in, too little time left to make it all happen!
Update: down to one ride, still too many parts, a little more jingle in the pocket, gaining space, and it's going to happen this year!
