Years ago, I had one in a low comp small block backed to a 4 speed and 3:23 gears. The 4 speed was its saving grace. I had a lot of fun with that car, and wasn't really worried about it being the fastest it could have been, it was plenty fast on the street. It also sounded awesome!
A buddy had that cam in an auto car, and the converter gave him fits, there wasn't enough compression or gearing to make it work, he was pretty miserable with that cam.
I believe that cam needs compression, a high stall converter, and gearing to work, or a 4 speed with a driver having enough ability to cover the weak points.
If I had one laying around, I'd stuff it in a motor with a stick behind it. Gene
