The reason calipers stick usually isn't due to the material of the piston. Poor maintenance is the cause. Not flushing fluid regularly allowing moisture to corrode the metal--aluminum or iron, of the caliper body, deteriorating rubber hoses, etc; fills the caliper body with crud/debris. The dirt then gets between the piston and caliper and locks it up.
**Photobucket sucks**
