Originally Posted By 68rrunner
Originally Posted By Viol8r
For you boys with QA1 front ends, it's an easy modification. Just order the correct width bar and arms, you are off and running. No mods needed.
http://www.colemanracing.com/Sway-Bar-1-14-x-48-Spline-P3795.aspx
Hows that stuff holding up? How many miles do you have on the set up?
I have the first one off the assembly line so I can't really speak for everyone. Mine was still in R&D form so I made a few tweaks to the lower controls and PS box angle. I changed all the bolts to higher grade and added some some material to each front mounting point so I could through bolt it to the frame rail. We noticed some movement under HEAVY usage (road course and autocross). Quality is good, all the welds, material and coating have held up great. I probably have 3000-4000 miles on it, but who's counting?! One day at the track is worth that!
1968 Pro-Touring Dodge Charger
*2011 Optima Ultimate Street Car Challenge Invitee
http://www.popularhotrodding.com/features/1203phr_1968_dodge_charger/index.html
