My Ar-99 is rated at 70 amps total. It has 2 circuits(each circuit has its own 40 amp relay), and they don't start at the same time it is integrated in controller to reduce peak load.
Thanks for the advice guys. Im going to use my AR-99 controller and wire the fans up separately. I will let you know how it goes.
Fans come Friday.
