These are aluminium hinges I made. Bolt up to factory holes on the body so you can adjust the door alignment. Also the rod end adds adjustment. Added bonus, doors lift off.
I tried lightening the original steel hinges but wasn't satisfied at how heavy they still were
Peter. Australian Charger, alloy block injected 410in, w9 na 9.03@148 leafs 3000lb
1967 barracuda 605 hemi Stage5 millennium 8.2@170
