Originally Posted By Old School
Originally Posted By fullmetaljacket
Clutch is a distant memory.
I have zero concerns about the clutch. It's a McLeod dual disk. Same one I run in all my cars. The other cars are a lot heavier and with a higher gear ratio. These clutches are almost bulletproof I have one that is over 20 years old without being touched!👍👍
Here are a couple pictures of the dual disc setup that I mentioned in the PM.
