Originally Posted By Little M
426ci hellcat block seems rather enticing! with the newer blocks, could you use the 32tooth reluctor cranks and older style cams to get away from the VVT and go with an MSD6 CDI? I try and keep it simple...
Yes on the reluctor wheel , NO on the cam. But all you need to do with the stock cam is lock it out. Comp cams has a kit.
