If you like the Lunati cams, it looks like the next one up would be a good choice for your combo. #10230704. 276/284 adv. 234/242 @ .050. .513/.533 lift. They recommend an 850 carb, which we already knew you needed. But they also recommend a 3.73 gear. You might get away with it with the stroker motor, though. Your compression, converter, and intake look good.
[image][/image]
