There are many dry 4500 throttle bodys out there I'm going to use dual 4150 1000 CFM dry throttle on the 572 C.I. pump gas hemi I'm building for a local customer so it will fit on the stock type Stage V EFI intake kit they offer with the 4150 bolt pattern Hopefully I'll be find a Shaker base plate to fit those throttle boys on that intake I will use dual 4500 throttle bodys on one of my motor with a tunnel ram intake with EFI also, hopefully soon
