Originally Posted By Jjs72D
I'm surprised nobody has mentioned that all factory 426 Hemi cars used the Dana when the 4 speed was used. You are now using an engine 102 cubes bigger with a smaller axle than stock?
I am a little surprised at that, too. But, then I suppose he will be using a Radial T/A type tire that is more for show than grip and that should keep the 8.75" OK for now.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
