It depends of many things, but it's propably not a brand thing. Like said above, usually the thinnest point is between the intake valve pocket and the top ring land. I believe this depends of the application, how deep and large are teh valve reliefs and how high is the top ring land. We have used Icons in boosted application, it's a 400 with 4.15" stroke 440 pistons, and so far no problems. But if you plan to make big power you should use custom pistons for boosted application.
Plynouth VIP '67 TT IC EFI
