I also swapped a front disc set up from a 70 cuda to another 70 cuda with an automatic floor shift, my problem is that the rear proportional valve bolts into the frame in the same spot that the reverse lock out z-bar bracket attaches to I think? that picture I would like to see if anyone has that combination..
