If you go with a 2 piece wheel you can have the exact back spacing built into the wheel...no spacers needed and you can center the wheels in the wheel wells just how you want to maximize size and minimize rubbing...
true but two piece wheels are stupid expensive! the wheel spacers were are $100/pair and the enkei's were only $1200. The minute your looking at custom offsets your around the $3000 mark, I would love to order a set of custom offset 18x11 0 offset would be perfect!
