So the 1 1/4" thick 3' x 3' steel plate with a 5th wheel hitch is removed from the bed tomorrow the old tank gets cut free and the bed floor gets replaced with plywood until I find the strip kit to redo the wooden slats. Fuel cell gets installed tomorrow as well, and then it's on to the tail lights finally. Already insured. Hope to be driving her by next Friday for payday.
dodgeconnection.com has the strips that holds the bedwood down. They have most all of the hardware for the utiline bed as it is basically the same as the LRE. I am hopefully seeing the light at the end of the tunnel (maybe it is not an oncoming Train) on a '79 Warlock II Powerwagon restoration.
