What year engine/heads are you using? Cam? It's going to look good in the 'Cuda!
It's a plain pre-Eagle 5.7L and a custom Comp cam. I spent my go-fast money on the T56 Magnum and will likely add some light boost to the 5.7 after the bugs are worked out of the car. I opened up the ring gaps a bit to help that happen.
