Problem isn't the kiss at the casting flash circles, that's a common issue easily fixed.
The problem is the poor machining on the front cam journal where the gear is rubbing on the pass side ONLY. Does the cam turn freely in the block? If so then it's probably not a journal alignment issue.
They say there are no such thing as a stupid question. They say there is always the exception that proves the rule. Don't be the exception.
