your possibly right Pittsburgh, but i thought 900 HP & 8k rpm limit might have reduced the possible options for good answers. i guess i need to be more specific even with that info.
so looking for...
6.535 length STEEL H beam rods
900HP power output
8000 rpm limit
565grm Custom Ross Pistons
No spray
4.250 stroke
am i missing anything?
Power really doesn't factor into it. That being said mine has a 7500 rpm limit, 4.5 stroke, 157 gram pin, 630 gram piston. If it's a bracket motor the aluminum rods might be out do to number of passes. I ran my BME 300 passes w/o issue before I swapped to Molnar (7.100/2.200/.990). Motor's never been on the dyno but will run 9.0-9.1@146-148 depending on weather at 3350lbs.
Doug
