Originally Posted By rednuck
Originally Posted By PUNK
I thought I read an article where a guy used the .842 diameter LS style solid roller lifters in the engine. Is there enough material around the lifter bores to overbore and install bronze lifter bushings? The rockers is definitely the other problem. The only rocker systems I know of are by T&D and JESEL and they are priced out of reach for the normal blue collar worker like myself.
PRW also has roller rockers, they are not adjustable though
I saw those and I'm hoping they produce a set capable of handling higher loads. I don't mind the non-adjustable aspect since there are ways around that.
Adriel Paradise
Substation Design Engineer III
