Originally Posted By GTX MATT
The blue wire the connects to the coil positive has power when the switch is on both start and run... IMO you have it wired correctly
Exactly! That's the way it is on my car and even in the MSD diagram. It DOES have spark to the distributor. You spin it by hand at higher RPM and it's fine. At cranking speeds, though, it doesn't spark.
I'm beginning to think it's a bad box...
