Originally Posted By GY3
Originally Posted By krautrock
turn on lead for the msd gets 12v during crank and run from the ignition?
I'm using the blue wire that originally fed + side of the coil. With the key on run I get good solid spark down near the box. It seems the further away I get the worse and more intermittent it becomes.
The blue wire goes dead during cranking unless you have the stock ballast resistor in place and a factory, functional ballast resistor bypass wire connected to the stock starter relay.
twocents
