Can I just watch the battery read out on my Racepak? That should be a real time voltage drop right? Or is that not accurate enough.
I really don't know Do you turn the racepak on after staring it or before? I see a lot of racers that have someone turn the Racepak on just before the run and the diver shuts it off with a master kill switch at the end of the runs
