Originally Posted By DAYCLONA
Originally Posted By Stewpar
So, car starts up on fast idle just fine. However, it won't kick down on its own or with throttle. I have to manually touch the plastic cam on the passenger side to get it to warm idle. Any thoughts?
Thanks in advance help
If it needs lubing, lube it as mentioned, however there is a small tang that rides on the various steps of the plastic cam for setting high speed idle, that you adjust by bending with pliers, perhaps it needs a tweak as it my be hanging up ever so slightly
Mike,now you know you use a screw driver in the slot rather than pliers !! no grin
