I'm transplanting a '79 360 from a Ramcharger 4x4 into a '81 Power Ram 4x4 currently with a 318. Are the motor mounts the same? I figure the biscuits are, but I mean the brackets that bolt to the motor. I plan to set the motors side by side because I have to swap all the accessories over, but just trying to rule out the motor mounts so I don't have to remove them if I don't have to. I have new biscuits for them.
Also, will the headers from the Ramcharger fit in my Ram? My 318 currently has manifolds...would like to use the headers from the Ramcharger if I can.
Thanks!
