Im in the process of the build where I'm mocking the downpipes up and trying to figure out where I'm going to be able to exit the piping. I have the turbos mounted inside the fenders and I have started to run the pipe up and over the front tire and have a straight shot out the side of the fender with a 90° bend but its going to land on a fender fin which well be a pita cutting in the fender with a 5 1/4 holesaw.
I may be able to put a 45° bend in which will kick the pipe down some and get it lower then the flare in the fender.
Where I need help is some ideas on laying out the thru holes so both sides are coming out in the same spot. I cant afford to make a mistake so I need some insight before i decided to pull the trigger.
