Sorry, no pic but mine come through the fascia, with
the main tube welded to the cross bar at the back of
the chassis with 2- 5/8 tubes welded to the same cross
bar to take the side loading(one on either side of
the main at about 45* angle). The main tube should be
at the height of your CG to pull straight without
any undo loading or un-loading of the chassis
