Data I have based on some bars in my garage is below. However, I believe the A body unit I have is a '74 and there are variations to earlier bars that I do not have. I also have an added dimension in a straight line from your dimension A to C but do not have the overall width, dim C
70+ B and E body A=27" B=10.125" C=no data D=8"
pre 70 B A=27" B=19.5" C=no data D=17.5"
A body A=23.5"B=15.5" C=no data D=12.25
I'd love to get more info on other options out there as well.
GM F bodies and GM trucks may be options. You can always trim the link arm length down to what you need.
Awesome numbers, thanks! I was thinking something along the lines of a Dakota or S10 bar might be close.
